wbalsam1
- Upper Jay, NY
Below, I've attached an essay I wrote for a local newspaper a while back. Thought I'd post it here for feedback/comments.
georgestolz said:How are we supposed to help you edit if you've already submitted it?![]()
Fred, interesting read. I find it very persuasive, but I have a question: what was the main objective of the piece?
cadpoint said:Good Luck with all that ...
My questions are:
1. Who inspects the city or County structures ?
2. Who inspects the State structures ?
3. Whats the insurance Rates of the Building inspectors ?
jshaw said:In the State of Idaho you must be a journeyman electrician for a least 2 years in order to be an electrical inspector. Some cities have their own building departments and their own electrical inspectors. All other areas are inspected by the State inspectors. We must also be certified by a recognzied organization. I have certifications with ICC and am in the process of being certified as a Master and Residential electrical inspector through IAEI. Both certifications require a proficiency test and the IAEI certification requires a practicum of supervised inspections as well.
I am a firm believer that electrical inspectors must be trained and qualified and receive continuing education to maintain proficiency. This is the only way to make sure that installations are safe and code compliant.
mdshunk said:Bravo!
You could submit that identical article in PA, and it would also apply. We have a system nearly identical to NYS. Inspector shopping is aggravating, especially when you're trying to bid. The low bidders bid with a certain inspector in mind, because they know where they'll be able to cut corners to save money, and still pass "inspection".
