Thanks, very helpful as a reference pointI generally figure 1 ft of 14/2 for each 1 sq ft of finished floor space, and I've rarely been off. However, I'm very proficient with wire usage. It's easy to burn a thousand extra feet by being foolish in routing circuits
12/2 can be a bit trickier depending on how elaborate the kitchen is, how far kitchen is from panel, how many baths, and the likes
14/3 can be tricky also because of how many smoke etectors, 3-ways, etc.
But *generally speaking* I've found it's 25-30% of however much 14/2 you need
6000 sf house I'm bringing:
6000' 14/2
1500' 12/2 (more if kitchen is far away)
1500' 14/3 (more if lotsa 3-ways)
What does this include/refer to?$3 sq/ft
"I'm very proficient with wire usage". I can't believe how many times I've seen like 10 extra feet on each romex home run at the main panel and 2-3ft hanging out of switch and receptacle boxes. I could retire from the scrap!I generally figure 1 ft of 14/2 for each 1 sq ft of finished floor space, and I've rarely been off. However, I'm very proficient with wire usage. It's easy to burn a thousand extra feet by being foolish in routing circuits
6000' 14/2
When I wire a roomful of receptacles, the only scrap is the EGCs I cut short for the greenies."I'm very proficient with wire usage". I can't believe how many times I've seen like 10 extra feet on each romex home run at the main panel and 2-3ft hanging out of switch and receptacle boxes. I could retire from the scrap!
I leave at least 15 extra feet on a 14/2 or 12/2 home run. Long enough to use somewhere on the next house."I'm very proficient with wire usage". I can't believe how many times I've seen like 10 extra feet on each romex home run at the main panel and 2-3ft hanging out of switch and receptacle boxes. I could retire from the scrap!
You can also go the other way and spend an extra 10 minutes trying to save some wire, and would of cost less just cut it long."I'm very proficient with wire usage". I can't believe how many times I've seen like 10 extra feet on each romex home run at the main panel and 2-3ft hanging out of switch and receptacle boxes. I could retire from the scrap!
Don't forget to factor in the time it takes to collect those extra length cut offs and carry to and stack them in the truck, move them out of the way when looking for something in the truck and then figuring out which one is long enough to use on that next job. $150 an hour seems high for residential new construction. Good for you!You can also go the other way and spend an extra 10 minutes trying to save some wire, and would of cost less just cut it long.
At $150 and hour that’s $2.5 a minute with 14-2 at .36 cent a foot
6.9 feet equal a minute of my time.
I’ll cut long and use it else were.
My sick sense of humor....lolWhat does this include/refer to?
I started in '92When I started wiring houses in the 70's (yes, aluminum, copper clad, bakalite boxes), we were doing we would have smaller houses to wire and my frugal boss would dedicate it to scrap day. We would load up scrap use nearly every piece incluing some short home runs, AC circuits, etc.
He didn't waste anything...lol
I fold back instead of cutting, makes it easier for inevitable changesWhen I wire a roomful of receptacles, the only scrap is the EGCs I cut short for the greenies.
