When you guys are asked to estimate a large project; for example a 6 story building completely fitted out. do you guys generally try to split the estimate up between estimater; for example have 1 guy doing lighting and branch power and another guy doing feeders and distribution and so forth because I just recently have been pulled into the office 6 month ago and am estimating larger projects all by myself and it is getting over welming due to the bid due date.
depends on the type of work you're bidding.... some stuff, and this is more in
civil engineering than anywhere else, you'll have the guy sitting there 30
minutes before bid opening, penciling in subs numbers, at the submission
location for the bids. after time's up, they open the bids right then, and every
body knows what everybody bid.
this process is not for the faint of heart.:smile: it can be extremely stressful.
it amounts to equal parts doing your taxes, the last 2 minutes in the
superbowl, and sex, all at once.
your stuff doesn't sound like that. taking off quantities can be done by a
number of people, and frequently must, given time constraints. those take off
sheets will go to the lead estimator, who'll plug it all into whatever estimating
software you are running, and quantities will go to wholesale houses for
quotes. large projects usually have a senior member doing the bid, 'cause
blowing a large bid can be the ruin of the firm.
if this is a new position for you, there should be some assistance and
oversight until you get the training wheels off. time for a candid chat with
the powers that be. far better to be candid, than to be thrown into a
sawdust pit for fight for your life, and cost the company a quarter million out
of pocket 'cause you were overloaded......
