- Bremerton, Washington
- Master Electrician
A common application is to have ethernet connected devices (PLC's and flat panel displays) in a PLC cabinet, which is UL 508 listed.
Typically the system integrator (who builds the PLC cabinet) runs the ethernet cables in the wiring trough with 120V power.
A ethernet cable is an Art 725 Class II application, and is not allowed in the same raceway, enclosure or box, with power and lighting.
Does UL508 allow ethernet cables in the wiring trough with 120V power?
