Hello everyone.
Im curious if anyone would have any hesitation feeding an EV car charger using the high leg of a 240/3 delta panel.
I have a condo building with an existing 240/3 panel. The panel is full except for all the remaining high-leg spaces but they are looking to add (2) single phase chargers which would either require a new panel, or require those high-leg spaces to be used. I would expect the EV chargers to be fine, especially because all of the ones ive seen do not require a neutral conductor but there are quite a few EV chargers out there and some may operate differently than others, or perhaps some check the L-G voltage indivudally.
Thank you in advance for the input
