Jcrist
- Spokane, WA, USA
I have recently installed a set of 6 electric vehicle chargers and everyone is giving me the same code of GFCI failure. The GFCIs are internal to the chargers and are single phase 208. We installed a new sub panel fed from an existing sub panel. I believe after further investigation of the existing system, I have found that the neutral is ungrounded. The neutral is ungrounded in the transformer, but unsure about the main panel do to a bolt that could be bonded to the back of the panel. I have exhausted all other options that come to mind.
Would an ungrounded neutral effect a 208 GFCI that doesn’t use the neutral?
