I was hoping someone had some ideas on this. About a year ago I installed a residential 40A Autel EV charger about 3' away on my 100A Murray panel from the 80s with a 50A #6/#10 thhn hardwired circuit. Checked all the lines, neutrals and the grounds including non related circuits for something loose but the charger occasionally faults out with a ground fault error. I'm not sure the house has two proper ground rods. Someone may have just gone to plumbing. Things are bonded in the main panel.
Resetting or plugging in the charger again and it works for a while. I've tested two different cars and it will fault eventually even if it isn't charging but just plugged in. Ie charging completed and later it faults.
Other thoughts were that something is wrong with the GFI in the charger. However lights occasionally flicker in the house and using a small welder causes the neighbors lights to flicker as well. The neighbor also causes my lights to flicker also welder use coincidently. The city came out but found nothing. Recently after a wind storm (well fire storm actually as 10k houses burned in my neighborhood) I inspected another neighbor's 200a panel up the block who lost his service drop to a tree and showed him the order to turn things back on later. He mentioned that he was thinking of replacing his two Tesla chargers because "they were old and erroring randomly."
This, of course, got me thinking even more about the city service having issues even before the storm.
So my questions, could a split phase imbalance on the line (city) side cause 240 gfis to trip? 120 gfi can function without a ground but I'm guessing that a 240 uses the egc ground lead as a neutral reference possibly. EV chargers don't have a neutral GC. Could better gec rod etc help? Could the city have a bad neutral? Anyway to diagnose a random situation like this?
I have a B license so at some level I'd include my electrician but I'd like to get some ideas. Thx
