bluecollar84
- US
I'm installing a wall ev charger in my garage do I need to install a disconnect as well?
If it is cord and plug then you don't need a disconnect .
Over 60 amps then the disconnect must be in site of
625.42 Disconnecting Means. For electric vehicle supply
equipment rated more than 60 amperes or more than 150 volts
to ground, the disconnecting means shall be provided and installed
in a readily accessible location. The disconnecting
means shall be lockable open in accordance with 110.25.
