LarryFine
- Henrico County, VA
- Electrical Contractor
I'm installing a 20kw genny (Generac clone). I believe the output breaker is 80 amps. There will be 25 ft. of feeder in the crawlspace, the loop behind the genny, and a few inches outside under and into the ATS.
1. Is there any reason to not use #2 al SER? What other options are as economical?
2. Can SER be run through LNFC? With control conductors? What diameter is the SER?
3. Thermostat cable is rated at 150v. Would that be suitable for the control wiring?
4. Is a disco needed where the feeder enters the crawlspace to run to the outside ATS?
