Ever Seen This Before?
Ebow
Did a meter to meter/main change out today. Problem was dryer and Air Conditioner quit working. I was a house about 50 years old and now a rental. Really crazy stuff had been done in the place.
Some one had tapped in to the bottom lugs of the meter to a sub panel. I guess they did not have #6 or #4 to feed the panel which contained two 2p/30a breakers so they so they paralleled two #10. Eventually it overheated until it burnt through to the point of melting the back if the meter. One set of the #10's where a little short so they spliced them real good (see attachment). What you see is the way they came out of the sub panel. I just cut them out with enough wire to show.
The dryer circuit came out of the sub with 10/2 romex and a #12 THHN and up the wall into the soffit. It came out in the laundry room as 10/2 UF with the ground cut out of the jacket and a piece of #12 THHN green attached to it as in the picture. Which ran down the wall and in behind the laundry room recepticle.
Man I love this work.
Gene
_______________________________________
Remember - Speed Kills and it may not always be you.
Gene
Well said. Crazy stuff like you describe keeps food on the table for us electricians.....and a few other toys in the garage.
As long as there is crazy, there is work to be done.
Hope you figure out that attachement thing. Love to see the pics. :smile:
Sorry could not get the image to post.
Just try and imagine the ends of the wires overlapped, then wrapped with very fine wire and soldered together. No tape, shrink tube. or any type of insulation over the joint. Just left bare inside the sub panel.
Gene
