Wants to know why it cost so much add claiming there are 4 empty slots in panel. Opening panel there are no buss spaces associated with the multi size panel cover and someone added electric heat onto a 100A panel on a home originally oil heat, without sizing load. BX and rag wire. Asked why they went to electric heat, "I didn't feel safe with oil heat." They "Got friends cousin Joe Handiman and he did it real cheap so we did it." Ground attached to water line that got replaced at some time with Plastic. Visual evidence of conductor heating. And why is it going to cost so much just to add the charger?
Seen it, just different reason for adding circuit.
Will likely see more of this. We've got a lot of old houses, renovated to look pretty but don't fix or upgrade to code the wiring while walls are open, no value in that.
