swhansss
- Bemidji, MN
am studying for the Oklahoma Unlimited contractor license exam. I am going through the Mike Holt Exam Prep book. I'm in Dwelling unit Calculations.
Why in the example calculations do you sometimes use 115 or 230 volts and sometimes you use 120 or 240 volts. I just completed some optional dwelling calculations and used 230 volts for an A/C load which is the voltage used on table 430.248. The sample problem calculated it using 240 volts. The difference made the total VA wrong on the problem I did. Will they be that close in calculating loads on the test?
