kshah
- Irvine, CA
Hi all,
I have a project I am designing where I am asked to provide power for a conveyor and screening equipment from a main electrical room (5,000 Amp main switchborad @480/277V) to a location which is over 1,000' away. In the past, for a similar project at the same facility, we utilized busway to span from the main electrical room to the project location. However, in the past, the distances was not more than about 600'. In this case, my load is approximately 4,000 Amps at 480/277V, 3P and I need to run the busway over 1,000'. This results in an excessive voltage drop at the distribution end at the project location. I have thought of providing a substation at the distribution end of the busway with common voltage on the primary and secondary so as to use the taps to bump up the voltage, but size and cost become a major issue. Does anyone else have any other possible suggestions on how to provide electrical service from a main electrical gear to a project location which is 1,000' away? Thanks for the help.
