I was asked to install alarms for a large exhaust fan in a caustic area in a plant. What they want to do is have an alarm go off if the motor is not working as the can not hear when it is running or not. There is a switching circuit for the fan in the work area but they leave it on all of the time. I know I will have to add a relay to power up the lights/speakers from the load side if the switching circuit going through the NC contact so if there is loss of power on the coil of the relay and the switch is on the alarms will sound. The problem I am having is I'm not sure how I should power the coil. If I come off of the load side of the disconnect by the motor that only tells me that a fuse blew and while that would show that there is a problem the motor could go bad and not blow a fuse. I thought about using a current transformer off of one of the legs because if it is not drawing any amperage that would be a better judge of whether or not the motor is working. The problem is as I understand it CT transform the current to a more manageable amperage but the voltage will also drop to millivolts which I think would not provide appropriate voltage to energize the coil. Are there any other Ideas as to how I can achieve my goal? Any advice is welcome.
