Had a problem with a motor starter which blew up about a month ago. The electrician that came out said it was a fault starter and needed to order a new starter. The replacement starter was installed yesterday and it also blew up. The electrician was confident it was the starter but now he was back to square one. We went up to the roof to check the exhaust fan and it was fine both physically and electrically, he tested the wiring with the fan removed from the circuit and results were 3k ohms between red and black phase everything else was open. Is this the problem I asked? He said yes. He then checked the isolation switch and it looked fine. He removed the switch from the circuit and test the wiring again with the switch removed from the circuit. It tested clear. Now he test the HUBBELL HBL7810D switch and the switch was reading 3k ohms between two phases. Has anyone experienced this problem with ease switches...we have several of these switches installed.
