swflelectric
- South West Florida
2 months ago we were called from an A/C Company to look into why several exhaust fan motors in a large pool supply warehouse kept randomly going bad. There are six of them on the roof(which is about 3 stories high) and they are being fed by 3 separate thermostats when 1 therm would go on it will kick on 2 units. The original contractor used a single phase rely powered by 24v and keep 1 leg hot to the motors all the time. We eliminated that gave each motor it's own 3 phase Motor Combination starter w/ 24v coil , and gave that panel it's own surge. Well since then 4 motors have gone bad on the roof and 2 of them were just installed. The motors are 3hp 480v (the new motors are invertor motors, the old are induction) the A/C company has maintained the motors, but I did noticed they grounded the metal enclosures on the roof(the motor is mounted to) but did not bring the ground to the motor itself. I opened the MDP and checked bonding and grounding, I looked at the buildings ground and it looks good.
What am I missing? We do live in South Florida during rainy season it is the tallest building in that area. What should be my next move to tell the manager Should I rent a lift and check the grounding in the pipes, should I upsize the grounding in the pipes, Should we call in specialist for lightning protection. HELP!!!
