I have a question to all of you. for Example:
If you have an existing service that has a 30KAIC rated switchboard and you are adding a new circuit breaker to that DSBN section, I would normally add a new 30KAIC rated circuit breaker. It has been recently brought to my attention that I cannot do that, that I would need to run a fault study to determine whether or not the system was designed correctly, due to the fact that it could have been originally done wrong. So what I have been told is that I would need to do this to all the existing systems we work on. Is this practical? Is there a section in the code that says I dont have to do this under the assumption that the existing service was designed correctly?
