in a existing bathroom that currently already has a 20 amp dedicated circuit for a GFCI and also has a separate circuit for lighting can you install a receptacle in a make up closet that is more than 6 feet away From any basin. The receptacle would be fished Up about 3 feet from the master bedroom Outlet which is on the same wall and that outlet is coming from a 15 amp source.
Does it need to be An additional 20 amp circuit?
Does it need to be GFCI protected?
