lmichael310
- Los Angeles, CA
I am involved in a electrical design that consists of relocating existing electrical conduits/wire and replacing a set of existing tunnel lights. The issue is that there are few if any as-built drawings available and there is a need to replace the tunnel lights and add additional lights to meet the customer lighting standards. In this case, the problem will be able to be solved because the existing lamps will be replaced with leds and the subpanel is labeled feeding the tunnel lights. However, this made me think what would be the best approach if I was presented with a similar scenario. From your experience, what is a good overall design approach when adding to an existing electrical infrastructure but there is a lack of as-builts and other necessary plans/doc to determine conduit routing, conduit sizes/wire and existing panel loads?
