Dan in San Diego
- San Diego, CA
Our local utility is starting the under grounding of electrical wires and the city inspector is telling my neighbor that since they cannot see the existing ground on his electrical panel he needs to put a new one in.
The electrical panel on his house has not been changed since the house was built in 1956. I verified that there is a cold water bond via an continuity check but again the ground rod is not visible. I tried to discuss with the inspector that since this installation has not been changed since new and passed inspection then, why now does a ground rod need to be put in? Let me clarify that all the utility company has done is bring in conduit (PVC) underground and run it along the exterior wall and install it to a box with a new meter base which in turn has prongs that go to where the meter used to be. Could it be that since this new box has been put in it may not be considered grounded?
I have not seen any thing in the N.E.C about bringing existing installations up to current code?
Thank you,
Dan
Thank you,
Dan
