Is there a way to determine what the maximum ampere rating of an existing meter socket would be if there’s no printed info inside?
Existing load center was a split bus panel so I really can’t go by an old main breaker size to help determine what it is amp wise.
Wire is #2 Cu.
Calculated load of the residence is 84 A.
I would like to install a 125A main breaker load center.
Changing out the existing service would be a large undertaking.
Meter base and riser are embedded in split shale stone and removing it would severely damage the stone work.
Also LB through and into the basement has been built over top of with a deck that would have to be cut open to access.
Thanks
Wire is #2 Cu.
Thanks
