malachi constant
- Minneapolis
I'm the signing engineer on a project that is under construction - existing golf course clubhouse will be torn down and the new one is nearing completion. The grounds contain a couple outbuildings - from what I understand they are basically sheds. I noted in the contract documents to intercept the circuits feeding these outbuildings and refeed from a breaker in the new clubhouse. Unfortunately we recently discovered the existing outbuilding feeders do not have a ground wire pulled with them. That's about all I know, and even then it's third-hand information. I am trying to get more information.
In the meantime I heard that the electrical contractor opined at a recent construction meeting that there might be a loophole in the code that allows buildings without plumbing to be ungrounded. As far as I know that is a ridiculous proposition, but I've been wrong enough in the past I figure it's worth running by you guys. Assuming there is no such loophole, I assume the best option is to rip up the feeder all the way back to outbuilding and replace with one containing a ground.
Like I said, I don't have all the information yet...might be a little too quick to say what the best option is or isn't until I know more...
