Is it code compliant to add a sub panel to an existing split bus panel or do they need to be replaced entirely?
I need to add 4 circuits. If I swap out the split bus I’ll need to bring the service up to code with Emergency disco new grounding and surge protection. To complicate things even more, the existing meter base is bricked in.
The panel is rated 125A and fed with #2 Cu.
The load on the house is roughly 90 amps per load calculation.
It would be fed from one of the 4 “mains”.
Thanks
Thanks
