Existing sub panel wired correctly (ground issue)?
I am adding a circuit to an existing sub panel in my garage for a pool pump. I understand the code for the pool, what I have a question on is if the existing sub panel is wired correctly.
These is a 50 amp double pole breaker in the main panel inside the house feeding the circuit. There are 3 number 6 wires in pvc conduit ran underground 50 feet to a detached garage. The garage does not share any common utilities like water or gas. The sub panel has the neutral and ground separated. There is a ground rod out side the garage that is connected to the ground bus bar. There was no grounding conductor pulled in the pvc conduit.
I have read many post on the forum and can not decided if this setup is legal and safe. If it is not what can I do to correct it before I start the wiring for the pool.
I am closing this thread, in accordance with the Forum?s rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
