bjp_ne_elec
- Southern NH
Have an installation where SE cable is up in a ceiling (a No No under 2005 or 2008) and it goes to a JB that sits on wall just below ceiling. As this was most likely (assuming here - you know how that goes) been there for the past 8-10 years (based on vintage of building) - can I extend off the JB and add a panel. This 100 A feed used to go to a piece of equipment. So disconnect and flex that was going to machine has been cut back to the JB. It's only a three conductor, so I can only put in a 208V single phase panel, using the uninsulated conductor as EGC?
Oh - and just to make sure - this is in a commercial building with drop ceiling. SE cable is routed up in the steel rafters.
