831
- South Jordan, Utah
Who here is aware of this requirement? Have you ever had contractors or owners questioning why you designed this type of lighting into the system?
Version of ICC? You mean the IBC? It's an ICC document.spsnyder said:In NYS we use a version of the ICC. It is required in 1003.2.11 under Means of Egress.
Regards
So you're familiar w/ it. Are the AHJs too? Is it regularly enforced? Perhaps a stupid question for NYS, but not so elsewhere.spsnyder said:To quote the ICC section regarding exit discharge...
1003.2.11 Means of egress illumination. The means of egress, including exit discharge, shall be illuminated at all times the building space served by means of egress is occupied.
There are some exceptions to that. Not sure your specifics.
SemanticsYou shouldn't have to say "It's Code", you could say "It's a life safety issue" if it helps you to feel better having a "follower mentality".
The IBC requires it, you enforce it.ryan_618 said:I always require it.
