Exit Light
eljefetaco
Fanwood, NJ
I am installing exit lights in a drop ceiling using a bar box. The bar is rated for 20lbs. and the box is a metal octagon with 8/32 screws. I cannot find any reason why I would need a seperate tie wire to support box. Is there a BOCA code? Anyone know if I need to do this? I don't believe the NEC code requires it.
Depending on the seismic zone that you are in the building codes might require the exit sign to be seismically supported in the suspended ceiling.
Chris
