mtfallsmikey
Well, I searched, could not find one definitive answer on this, so here goes:
6-story commercial building, built in 2002 under '96 BOCA building code, emergency life safety generator not required at that time, but previous tenant installed 2/750 KVA generators, enough to power the entire building under full load. Most all of the exit lights in the building do not have battery backup installed. We had to transfer to generator power for the annual elevator test, tenants noticed that during the 10 sec. or so time that it took for the transfer to generator power, that the exit lights went out, and indeed, none of them have battery backup, all emergency lighting went out except for the lights that had batteries, in the common areas. All exit lights, and emergency lighting in the building are on dedicated circuits for each floor. There have been 2 tenant buildouts within the last 3 years, and on each, none of the AHJ's required the installation of exit lights with battery backup... Is it a requirement in NEC/NFPA/IBC to have them?
