jmgreer
- northeast arkansas
hello, this is my first time to ask a question on the forum. my question is in regard to a inspector directing me to use a exothermic weld to connect my egc to the structural steel. the print directs me to install per nec 250.30. it is a single seperately derived system and i used a mechanical lug to make this connection. would someone direct me to the artical in the code that says that a exothermic weld is the only acceptable means for this connection. thank you
