yordanys
- New Jersey
- Electrician
Hi Guys,
The only place where an expansion fitting would be utilized is where the concrete itself has an expansion joint 300.7(b), but my question is, Do I have to be right at the expansion joint or I have a specific room where I have to install the expansion fitting? I mean can I installed it before or after the join any required distance from the join?
Thank you in advance.
