Hi, I’m running some 1.5 EMT on roof plans call for expansion fitting for thermal expansion if more then 20 feet of a straight run between box termination. Also states use straps that allow movement. plans quoting 300.7b. Plans do not provide how much it needs to expand. Plans also shows a bonding jumper between expansion fitting and EMT I’m thinking they want PVC expansion fittings. It’s on one building. Project is 480 volt 1.5 emt feeding the AC side of a solar edge inverter On a Corrugated metal roof emt is Secured on 6” Duro blocks. I’m thinking I don’t need expansion fitting?
