Is flexible metal conduit acceptable for use as an expansion joint?
E ethan Member Location Michigan Apr 7, 2003 #1 Is flexible metal conduit acceptable for use as an expansion joint?
E ethan Member Location Michigan Apr 8, 2003 #3 Re: Expansion fittings Originally posted by luke warmwater: for what application?? Click to expand... For use as an expansion fitting at an expansion joint in a building, allowing the building to expand and contract.
roger Moderator Staff member Location Fl Occupation Retired Electrician Apr 8, 2003 #4 Re: Expansion fittings Ethan, I have done this many times. Be sure your grounding (bonding) is up to snuff when doing this. I think it's actually a better method than expansion fittings IMO. Roger
