PVC straps that allow for movement will be used to support the run using threaded rod and flange. There will be skirting on the home. Will not be exposed to direct sunlightAnd what is the temperature range to be expected in the crawl space?
That reduces your temp extreme range from say 140 degrees to maybe only 70 degrees.PVC straps that allow for movement will be used to support the run using threaded rod and flange. There will be skirting on the home. Will not be exposed to direct sunlight
