gserve
- New Hampshire
Does the PVC conduit have to be a certain length before an expansion joint is required in a horizontal run of 2" PVC under a mobile home?(Has to be ? feet before one is required)
352.44 Expansion Fittings.
Expansion fittings for RNC shall be provided to compensate for thermal expansion and contraction where the length change, in accordance with Table 352.44(A) or (B), is expected to be 6 mm (1/4 in.) or greater in a straight run between securely mounted items such as boxes, cabinets, elbows, or other conduit terminations.
