Expansion joints
Can u run emt through an expansion joint? Or use flex as a fitting
Are you talking about an expansion joint in a concrete slab, or a building expansion joint?
A building expansion joint should be traversed by a flexible connection capable of absorbing the expected deflection. I have seen it done by laying a piece of flex in a zig-zag pattern in some interstitial space to accommodate vertical and horizontal movement.
If I understand what he is asking.
Through a joint.
Usually there is a gap wide enough for a 1/2" EMT.
Some have a key way and will not allow you to go through and others have a full gap all the way through.
Seen this on tilt ups with welded seam plates and gap that has backer rod and sealant.
So through or across?
Through a joint.
It’s across the joint. And it’s through the whole building.
