What is the best way to install conduit underground where you have expansive soils? We have a project where structurally they are installing ?Void Boxes? that will deteriorate after the concrete is poured creating a void under the slab and it would be supported from the associated drilled piers. I was instructed to install the conduit prior to the ?Void Boxes? being installed but what happens when the boxes are gone and the slab is suspended 12? above grade how do you install the underground conduit? When the soil expands I do not want it to affect the feeders and conduit in witch they are installed. I tried searching the net but could not find anything regarding this with electrical conduit installation has anyone ever encontured it and if so how did your handle it ?
