tonykuphaldt
- Pullman, WA
- Instructor
I'm designing a very low power (under 100 Watt), low-voltage (21 VDC) solar-based power "grid" system for my Electronics Engineering Technology students, the purpose of this system being to provide them with a "test bed" for incorporating power-conversion, regulation, and protection circuitry they will design, build, and test. The system will be inherently safe, in that it cannot shock anyone or overheat any of its conductors due to the intrinsic limitations of the solar panels. Any protection modules students build will be unnecessary, only serving an educational need and not a real safety need. So far the plan is to use cable tray to route all the conductors (16 AWG TC-ER cable) along the lab room walls from the panels to NEMA-1 junction boxes where student's experimental circuit modules will reside. The entire system will be indoors, the solar panels mounted up against a large south-facing window.
Ideally this system would fall under NEC Article 725 as a Class-2 power-limited circuit, but so far I cannot find where a low-wattage solar panel is listed as a Class 2 power source as per NEC 725.121(A), nor listed for parallel interconnection as per NEC 725.121(B). At this point I'm thinking it will have to be regarded as a regular Article 690 installation simply for lack of appropriate listing of the panels.
In the not-too-distant future I'll approach my region's AHJ for approval of our plans, but would like to have as much supporting documentation as I can prior to that meeting. Does anyone have experience with power-limited solar electric installations?
Thanks in advance!
Thanks in advance!
