Hey all... when i have a prob this is where i come. Problem: I've done very little work with neon. I've taken on the task of repairing all of the neon on a local adult club. The club is trimmed in neon, neon sign, etc, etc. Some of the neon is working fine, some isnt of course. Today I began my task. I got on the roof where the neon ballasts are. (Remember, I've done little to NO work on neon before.) First thing that comes to mind is maybe a ballast or 2 is bad. I felt certain this one particular ballast was bad so I replaced it. I felt it was bad because I traced out the 2 secondaries. The secondary on the left side of the ballast seemed fine, those lights working.... the secondary on the right side of the ballast, those lights not working. The more I got to looking the more confusing it got. Well, I went ahead and replaced the ballast with a new one, the new ballasts appear to have some sort of ground fault system built in.... it detected ground fault therefore the secondary of the ballast wasnt working. NOW, of course, the neons from BOTH sides of the new ballasts are out. Well, I start doing more looking, I find that the way its wired is 2 ballasts per neon fixture. EXAMPLE: If I trace the wire from the left some of ballast A. and the wire jumps from neon to neon, it'll end up on the left side of ballast B. Is this standard practice? I would have figured the opposite.. I woulda figured if I trace the wire from the left side of ballast A. it would take me to the right side of ballast A. Am I way off track here or is this wiring not common?? Thx all. Jason
