KyleFowler
- Maryville, TN
- Electrician
So my co-workers are going to be hooking up a propane pump and since I'm the guy with a codebook they are asking me questions about the proper way to do it. So I've been reading Article 501 to learn. It seems like all the work they are doing is going to be in a Class 1 Div 1 area. My question is do explosion proof boxes typically need seal offs on the conduits coming into the box if the conduits are less than 2" in size and the box contains just wire nuts? I see seal offs are required if the box contains switches, outlets or other "ignition sources". Are wirenuts considered ignition sources? I know wire nuts aren't exactly ignition sources under normal circumstances but I think we have all seen our share of burned up wirenuts! Basically I'm asking to cover all the bases. An example of a box with just wirenuts would be the box at the motor.
Thanks in advance for probably a dumb question lol
PS-holy cow, explosion proof flexible couplings are expensive!
