Aesop
New member
- Knoxville, TN
We are placing handholes at key points along a bulkhead to feed power to gas/diesel fuel dispensers used by boats moored next to the bulkhead. While the handholes are not in the C1D2 area, the conduits entering the handhole cross under the class I Div 2 zone. As a consequence, I need to seal the conduits per 2011 NEC ( see illustration in handbook exhibit 514.5.)
The twist is that I'm not bringing the conduits up above ground to be able to place a seal off in the conventional location. Instead, I need to seal them as they enter the handhole. (the entire bulkhead is a "freight handling" area and above-ground panels would restrict movement and would soon be destroyed - that's why the handholes).
It seems that a conventional explosion proof fitting would work and would be accessible if placed in a handhole.....but I've never seen it done.
Is there any experience with installing explosion proof fittings on galvanized rigid steel conduits within the boundary of a handhole? If so, what methods would be advisable or avoided?
Thanks.
Thanks.
