burchie
- Jackson, SC
Greetings,
I have a metal structure being built and it will come in three sections. the outer two sections will be completely built and welded where as the middle members (6 tubes) will be added at location. The tubes are painted and will be fit together with bolts. I have to ground/bond this for a chemical plant and it will house tanks of gasoline.
Since the bolts are painted and the steel tubing is painted I though I would have to add 12 bonds (6 on each side) to make the structure continuous and then ground to the grounding system.
Please tell me if I can get away with less than 12 jumpers and be secure.
In the drawing, you will see two separate sections and then a single section of tubing that will be bolted to the other two side sections. All members will be painted prior to shipment
