muddyboots
- Florida
- Electrician
Got a window mounted indoor exhaust fan with a single gang service switch inside the fan housing. My question is does the wire need to be concealed in conduit inside the fan housing, going to the service switch? There are 1/2" concentric knockouts on each side of the fan housing, which I would ordinarily just flex or pipe into.
If it does need to be concealed, could I knockout a hole big enough to fit 1/2" flex and go strait to single gang switch, without there being a connector on the housing? And would that void the ul listing? Thanks for your time.
