Hey folks,
I've run into an awkward cabling problem and would appreciate suggestions on how to tackle this one.
Should be an easy job: I just need to terminate 12/2 AC to a 4" metal box. The conductors are long enough to enter the box, but the problem is the cable jacket comes up short of the box about two inches. I can't easily re-run the cable or move the box, as both are plastered into a shallow brick chase.
My current thinking is to run the conductors in EMT for the last foot or so, using a low-profile EMT/AC transition coupling (e.g., Bridgestone 280SP). This will work, but is far from ideal as it requires deepening the chase to accommodate the fittings and EMT, and making precise offset bends in the EMT to line up with the box.
Appreciate any suggestions folks here may have on better options!
Thanks,
Noel
Thanks,
Noel
