Logan2112
- Klein Products
- Journeyman Electrician
There's a project coming up that will require two (200 amp) single phase 240v panels (in a shop) to have their main disconnect locations changed. A new utility side will be ran on the line side but, the existing wire is not long enough to go to the new disconnects from the panels. I do not like the idea of splicing an extension to each. I would much rather pull out the wire, build the new conduit run and pull new wire to the panels. The problem is TIME. This would require a much longer "down time" for the facility to do the switch over. I suppose I could just do one panel at a time and schedule them on different weekends.. Anyway.. Thoughts??
