Scott in Round Rock
Please point me to the approved methods to extend a neutral in a load center in order to retrofit a standard breaker with an AFCI. I've rewired a sub panel by rearranging the breakers a bit, but I'd rather extend a short wire than to have almost no slack in it.
I'm thinking solder and heat shrink insullation.
To future proof a new installation:
Is it a common recomendation now to leave the wires equal length and "coil" the extra length of neutral if the bus bar is closer than the distance the load wire has to travel to get to the breaker? I would think as new breakers come into the market, it will be more common to wire the neutral and load to the breaker and pigtail to the bus, as in the AFCI.
Thanks -Scott
Thanks -Scott
