jeff48356
- Livonia, Michigan
Consider the following situation: A homeowner is remodeling his kitchen, and needs recessed lighting installed. The house was built in 1953, so none of the wiring is grounded. There is only one light fixture in the kitchen, and he would like that changed to a recessed can light, plus run 4 more cans off that, for a total of 5. What does the NEC require for grounding, since no EGC would be available at the original lighting outlet?
