We have a situation where we are using many twist locked receptacles located above at the ceiling in classrooms area with a yellow factory pre-made SO cord cable with a twist lock on one end (above) and (2) Nema 5-20R duplex receptacles on the other end (drop down). The purpose of this wiring is to give the owner felxibility to power a cluster of computers and monitors. The inspector have said Reloadable Power taps are not intended to be used in series connected (daisy chained) to other relocatable power taps or to extension cords. My questions:
1. Can power strips be plugged into thses two receptacles?Or would this configuration be considered "Daisy-chaining"?
2. Would this yellow cord be defined as an "extensior cord"?
3. Is a twist lock considered "Hard-wired"?
Your thought is really appreciated. Thanks,
