I will be installing several exterior lights for new construction on a home with stucco walls. As per the 2011 code, it appears that I cannot use NM, MC, or even UF through the wall to the back of the box if I am reading this correctly. Is stucco considered concrete? Aggregate? I was going to use NM to the back of a stonco box, but now I'm not sure.
I see that Arlington has a box #FR420F. this may be the way to go.....
