Rob Lorton
- Colorado
- Electrician
I have a 1” PVC conduit feed from the panel to a pole light. This is existing. I want to pull another separate circuit thru the 1”.
The separate circuit will run thru the pole and feed an EV charger. Two Questions: Can I use the pole as a junction box and can I run a conduit from the pole to the EV charger. No splices. I would have to pipe near the hand hole cover and down the caisson. Not sure if this makes sense.
