Electromatic
- Virginia
- Master Electrician
I need to rough-in boxes for exterior lights, receptacles, door access systems, etc. From the outside edge of the metal studs to the finished exterior is about 3". Any advice on box/mud-ring mounting options?
I've considered a 2-1/8" deep 4-square with about a 3/4" mud ring mounted to the outside of the stud, but then I'd have to offset the conduit from the box back into the wall through the insulation, etc. To avoid that, I could mount the boxes in the wall then use a deep extension ring and a mud ring, but that seems like it would get pretty flimsy.
Ideas?
thanks in advance
Ideas?
thanks in advance
